what bearings do i need for a 1992 magnum (outside bearing).i had the 101-30 on there before its like 25 dollars but apparently its not the right one. what is the bearing that most people use?
bearings?
Personally I'd go with the new Argo 72mm bearing on the corners, and synthetics in the center. Contact Adair Argo Argo HD Bearing Adapter Kit | Adair Argo Sales - We Ship Worldwide!
New Synthetic Outer Bearing | Adair Argo Sales - We Ship Worldwide! They will help you out.
The original bearings were 62mm outer and 1 1/4" inner, so the number was a 206-20 and the letters designate relube, set screw to shaft, and what type seals. 206 means 62mm and 20 means 20/16" shaft.
