I installed the rear winch mount kit on my Scout and it seemed a little low once I got the winch pinned on so I was trying to think of a good way to raise it. I didn't want the expense of having something fabricated so I decided to use a receiver hitch riser.
I had it cut and drilled at a machine shop for a more custom fit and I think it is going to be good setup for using the winch for rear pulling in wet areas. My plan is to use a snatch block and hook the cable onto the D ring so that some of the pulling force will be transferred back to the hitch where it is mounted to the frame. I can leave all of the parts in place and still use the rear rack braces but they have to be put up out of the way when installing the winch.
I have no experience winching so if anyone here sees an issue with this setup please let me know.
This is the height of the winch with the stock kit.
This shows the difference in height with the hitch riser installed.
fail yet in our club. Not recommended but I have seen a second Argo winching the hitch of a first Argo who was winching a stuck pickup. I was afraid that the ball on the first machine would become a projectile but their luck held out.
