Hi I have a 93 6x6 Vanguard, rebuilt about 100 hrs. ago. After about 5 minutes od driving I cant ease on the left break, it grabs, making it harder to control. I've taken the mechanical brake apart and cant see anything wrong.
Break Pad Grabbing
Has this issue been ongoing since the rebuild or shortly there after or just something that poped up? I had the same issue with my conquest when I bought it. The prevous owner had done a maintenance and oiled the idler chains. some of the excess oil had migrated to the brake discs. I had to give allot of brake forse to turn in either direction. After testing the machine out for about 10 minutes the brakes would just slide through and then suddenly lock up or grab. The discs and pads were glazed with a sticky residue. i removed the pads, calipers and discs and cleaned with brake clean. I then sanded the discs and pads with a 120 grit. (do not use brake clean after sanding) all was good after that.
Hope this helps
Dave
Pads being adjusted evenly makes a difference. Is it possible the pads got reversed and are sitting slightly cocked (previous wear from slightly off mounting point, pads thick on top and wore on bottom or vice versa, etc..)?sigpic
