Has anyone ever thought of or put those small Amber side marker lights on an Argo? Just thought of it and thought it would be cool to have some on the side! How would I wire those lights specifically? Thanks send pics if anyone has ever done it so I can get some ideas!!
Marker light wiring?
Browns are usually ground on argos, just pick the front left headlight, and follow the wire to where it is easier to work withOriginally posted by curtisbyrne View PostOk thanks! There is a red and a white wire which one is ground? And what colour is the headlight wire and how to I connect it to that wire? Thanks guys for the help I'm not really got at electrical so all the details I can get would help a lot thanks!
You can daisy chain all the marker lights you want. I think 2 a side and 2 in the back is no problem for the wiring. Better yet, put in a switch, run 2 new wires from the battery and you can switch it on separately. That way you can have it on for a few hours if you want the argo easier to find at night without draining battery too much. I ran a new wire to a power outlet, run my bilge pump off it, and was going to run interior lights off it
It's low current it's fine. But I'd still get the liquid electrical tape and insulate it thoroghly
If you're worried, there is a ground block on the firewall by the gauges. Run your ground there. Then run the other side to the light switch so it's on when switch is on.
