I have all the chains of my Argo and it is double 50 all around and last season had some vibrations when turning right? My chains right up in the front are good but on the left it is loose. Replace chains or just clean them up and use them again? How do I tighten the chains in the front? Thanks
Argo chains stretched
Loose chains will cause the problems you indicate and when turning will give sluggish performance. The front chains on most Argos have no factory adjuster because they are so short. The option is like I said above. I prefer to have adjustment built in and use the adjustment to increase chain life. Your other chains have adjusters, and as long as they are operational you can clean and lube them and reuse. Sometimes the chain adjusters will get debris in their workings and you will have to grab them and give them a pull or push to reset the mechanism. Hope this helps.
Remember when replacing worn chains to count the links and replace with the same number.. A stretched chain will be longer than a new one with the same number of links, but if you only measure you could be making them longer than original..Originally posted by curtisbyrne View PostI measured the 4 rear chains and each chain is just over 5 feet ( 5 ft mark is half way on the last link) and one chain is 5 feet exactly. I tried all these chains are touching the frame when I put them on. Can I take a link out or ?
