I just finished wiring my brake blower fan up to a toggle switch!are there any other things I could wire up or any other cool assesories I could put on an Argo?( fog light, side marker lights)?
That plastic connector meted due to a wire that was exposed to rust and what now, what else would it be you know, so I hope that the cleaning of the stator and new regulator should do the trick, once again what else would it be.
Yea I'm not a bid water user in an Argo more mud and land not water. Thanks tho!
If regulator is done will lights blow or still work because all my lights still work so maybe I don't need a regulator?
You are going to want your winch on a separate circuit with separate controls. Too much amperage for a normal toggle plus you want one that goes off when you let off the switch.
On my machine I have my electric fuel pump (not only can I turn it off for mechanical reasons but also doubles as anti theft), my brake cooling fan & my headlights run through a panel with toggle switches. Just remember EVERYTHING takes juice & we don't have much output on our charging systems. I went to inexpensive aftermarket LED lights for headlights as a power saver & disconnected the stock lights.
