Alternator on a magnum?
  • Alternator on a magnum?
    I'm looking for anyone who has put an alternator on a older Argo like a magnum or conquest etc. Or has personally seen it done. I see an empty pulley on the side of my engine, I took a picture of it and I'm wondering can I just mount a small alternator somewhere and run a belt from that pulley to the alternator? I've seen alternators that have only one wire to the possitive post on the battery & a belt to hook up. Seems simple enough and might solve my charging issues.
    "I've yet to encounter a problem that cannot be solved with the right mixture of whiskey and weaponry"
    :ME....
    " From my cold dead hands"
    :Charlton Heston...
    ive not done it but it should be very simple. use a GM one wire alt.
      A member by the name of classicplug has it done on his magnum
        Go to gallery and type in 1990 Argo magnum external alternator! I used this too and think it would work very well but I'm on the edge of selling mine so no need, looking at a 2003 conquest!
          That sucks you are gonna sell Curtis... If you lived closer i might have been interested
          Thanks guys for the info !
          :ME....
          :Charlton Heston...
            Ok, to "Clasicplug" wherever you are thank you ! thats awesome & just what i was thinking ! If you compare his pic to mine you can see that the black plastic "shroud" that you see in my pic has been removed to make room for the alt. Is it not needed ? I dont even know its function.. Anyone know if its ok to remove it permanently ? I edited my orginal "thread post" to add his pic to save you guys the trouble of searching the gallery, thanks again guys.
            :ME....
            :Charlton Heston...
              That plastic shroud appears to serve the purpose of providing a cool air intake system for cooling purposes. The flywheel (which is behind your pulley) has fins on it designed to pull air into the engine cowling to aid in cooling. Because AATV's have their engines tucked down into a cubby hole of sorts, it can get pretty hot and thus leave an air cooled engine to try to cool itself with hot air. You will notice some members have fans mounted to their machines. This is to pull the hot air out (or push cool air in). I don't know if removing the shroud will cause a problem. I guess it depends on your climate and driving style.
                Keep the shroud for sure, cool air for the motor get sucked in there. You could prbably modify it for te belt to pass through to the alternator depending on where you mount it.
                  Hi Kris
                  There is no lower bracket. Its all mounted on the threaded rod.
                  I recently talked to another member about what I did.
                  Here is what I said
                  "It works great and was easy to install. Its the best thing I have done to my Argo.
                  The only issue I ever had with my Argo is when away hunting the battery would drain and there is no power where I go.
                  Once I figured out how and where to put the alternator it was fairly quick and easy to do.
                  I mounted it higher do to having some water in the tub when hunting when its raining, that way it hopefully stays dry. I have not had a problem with it yet.
                  I used a marine alternator and once the engine is revved up it charges until the engine is turned off. I also use a vehicle battery that fits the battery box well.
                  I did not have to move anything, I just bolted the alternator in. I used 3/8 threaded rod as that was the bolt size for the hole and ran the rod to each side of the engine access and ran the threaded rod though the angle iron. Leave enough room on the inside of the angle for the bolt to fit on. I put lock washers where I could to keep it tight and it have not come loose in 4-5 years.
                  I ran the belt off of the engine pull start pulley, not supposed to do this, but I have not had a problem with it yet. I used a Goodyear belt # 84310. I went to the auto parts store I use and exchanged belts until I got the proper one.
                  It is a marine alternator and can be spun in either direction and only needs one wire run to the positive side of the battery. Once the engine is revved up it charges until the engine is shut down. It has a built in voltage regulator"
                  This should be a link to more of the pics of what I did argo external alternator - Amphibious ATV Pictures
                  Sorry for the length and the duplication of anything. It was easier for me to cut and paste, I would have been hours typing it lol
                  I think the other pics are in an album titled "1990 Argo external alternator" in case you have not seen them all.
                  Stu
                    kris did you end up doing this..... i was sizing it up and i think you can modify air intake to fit with the alternator! also is your magnum charging now or no?
                      No not yet, however I'm considering doing it very soon. My main concern is, Stu stated he used a "marine alternator" that could be spun in either direction. I was looking at a "mini chev, one wire alternator" on eBay that pumps out 35 A which seems about right for a small engine like the Argo house. But it's not a "marine alternator" and truth be told I don't know a hell of a lot about alternators... for instance I don't know how to tell if they are a spin one way only or spin either way etc. So I haven't decided what to do yet.
                      :ME....
                      :Charlton Heston...
                        That GM can be spun either way, the ONLY difference between CW and CCW is the fan direction under the pulley for cooling. Get the right rotation if you can but don't worry about it at all if you cant. I wouldn't bother ordering one from Ebay though, your making due with the best thing your search turns up...Go to a local alternator shop and tell him what you want and buy a rebuilt for a fraction of the cost.
                        Here's a link to my alternator upgrade on my max, I used a 37 AMP 10 SI that I paid $80 cdn for locally.
                        I just called Commercial Alternator & Starter on Raleigh Rd Oshawa, they have lots of 10-SI alternators in stock 35-60amp, your choice, $110 each.... The Indian guy in Pickering is a bit cheaper but Commercial is in your neighbourhood
                          kris if yours os charging with the stalk there is no need unless your running some extra lights and accessories.... when you trashed your stator you still needed to buy another one right Canadian zuk.... thats what gives spark to the spark plugs?
                            No, the stator is just the charging system. The motor will run with no magnets as long as there was power in the battery. I just gutted everything under the flywheel and left the external regulator where it was. The alternator now does the job of tue stator
                              right its the air gap between the coil and the flywheel outside magnet that creates spark
