well thought i time for a bit of bling.first a winch,superwinch T1500,uesd the brace from the parts machine.(it had a atv 750 LBS)seems quite small,the t 1500 was on sale,$120 so i went for it.also added a tiny tach,and 2 stick on convex mirrors
Added some BLING to my old 78 6 wheel
order from [URL="http://www.tinytach.com"] ,wireing is easy,ita a coaxal cable,outer goes to engine ground,inner wraps around spark plug wire min. of 3 wraps.no connection needed!make sure to order the right version for your application
sorry the link didnt work
Looks good,
I like the Tack
Don't be suprised if the 1500# winch is not enough sometime. I run a 4200# winch on mine and have stalled it on a number of occasions. At the very least I think you should have a "Snatch Block" with you, just in case.
(Around here, even quads use a min of 2000# cometoome
lol, I love the idea of having a button marked "Ejection Seat"
yes i have a snatch block
,prior to the winch i only needed it twice,and i wanted to keep it light on the front.also the bracing for the winch is the old clamped together type,i think the newer ones are welded.i wouldnt trust a big winch on there.the parts machine i got the bracing from had a 750lb winch on it,i figured this was a step in the right direction
You never know till you try it
