Hello all,
I've got a 97 Bigfoot that runs great except one problem I've been dealing with since I've owned it.
It loses rpms going climbing hills, not because it doesn't have enough power but because it will not back shift under load unless I stop.
For example I can climb any hill if I start slow at the bottom and just don't let the rpms climb, but if I was to open up the throttle enough to allow the belt to drop into the shelves I will eventually bog down. It's only if I stop, then the belt will come back up.
I've done all the servicing I can think of according to manual, new spring, new brass bushing,cleaned, lubricated as per manual.
Spring is in hole#2 and has been wound as per manual.
No other issues....that I know of.
I want this machine to maintain rpms going up hill at full throttle....the machines speed should slow but rpms basically should stay the same, just like a snowmobile does when climbing. I'm beginning to wonder if this is how these machines just are...but have nothing to compare it to.
Any solution is extremely appreciated
Thank you!!!!!
Thank you!!!!!
. Of course that may be the highest priced 3 chunks of lead ever sold to any man anywhere, so being redneck as I am I'd just drill some out of each weight and make sure they're all equal weight. If that didn't work, I'd melt an old wheel weight into the drilled holes to replace the missing lead. This is something I might actually do myself if I feel like banging on my argo with wrenches and hammers again any time soon.
