what do people here use for their tie points on an Argo for holding down cargo in the back?
tie downs
I generally just pile it in. Haven't had anything pop out yet, save for a ball cap that blew off my head lol. If your piling it higher than the sides of the machine I would consider something like the hand rails for the back that argo offers. Shouldn't be to difficult to make something up with a bit of round stock.
The one thing I do tie into the back of the argo is my guitar case when going up to the cabin. I stand the case vertically against the seat back rest and tie it to the gun mounts I have mounted on the top of the back rest.
I tie a paddle/shovel/gas auger up across the backrest of the seat with a bungee cord or two hooked to the back rest bars that's about it. They all are about the right length to sit there. When sitting over night in rain if I'm out overnighting I toss a tarp over the whole thing and ratchet strap the tarp down by putting the hooks on the rub rail. I suppose you could do the same thing with the tarp just over the back if you needed stuff to stay dry/stay in place there but usually I just leave the tarp over the stuff and tuck it into the gaps by the seats to keep it in place when travelling.
Rock Doctor...your set-up is great! Can you post a couple pics from looking straight at the rear, so I can see how you have attached the rear brackets? I need to add a support in the rear for my hard top. The original was attached to the hitch I believe, but don't know for sure. Some pics of yours would be very helpful!!
Thanks....AkBillyBow
I don't have a rear support on this machine, the rack is just bolted to the Splitline around the Tub. These older machines seem to handle the weight better than the newer machines. I have had to add rear support to a couple Avengers, but we did that from the inside. (sorry, no pics). A 3-4" wide piece of flat bar bolted to the rear frame, and molded to follow the rear contour of the tub, up to the Splitline works well.Originally posted by AkBillyBow View PostRock Doctor...your set-up is great! Can you post a couple pics from looking straight at the rear, so I can see how you have attached the rear brackets? I need to add a support in the rear for my hard top. The original was attached to the hitch I believe, but don't know for sure. Some pics of yours would be very helpful!!
[IMG]
[/IMG]
tie downs
I actually had a rear seat passenger complain that there was so much exhaust smell in the back seat that it made her hair smell on an extended water trip.?? It might be a problem with the top up and the passenger window removed? I have watched many Rock Doc movies in snowy weather with no roof and seldom a windshield and sometimes a huge load of plywood. The guy is tough. Please Doc,more movies.Originally posted by grease monkey View PostI have considered shortening mine, my only hesitation is I don't want to end up getting exhaust gas in the cabin once I put my roof up
