So I bought 2 Argos to hopefully make one workable unit. I have read a lot on here but I am sure I missed some of the answers to my questions so I will ask them here.
I have no idea the year of it, still need to pull the serial number off the dash (if it is even there)
- The unit came with a snowmobile engine and I am replacing that with a v-twin 4 stroke. The clutch came off it just fine, but it is for a tapered crank shaft. I read about using the adapter shaft that is sold on ebay, but did not read how well they work. Any success stories?
- I also have another clutch on the 2nd engine that came with it, I am hoping it is a keyed clutch, and if it is I might just use it. my worry is how serviceable it is and if I need a different belt for it.
- The chain tighteners all need work, they are the ones that look like a "L" and have a sprocket on them. I saw that McMaster sells new sprockets for them, but is there a better solution that someone sells?
- Why does it seem the norm to go from the 3 bolt to 5 bolt axles? Mine are 3 and seem fine.
- Finally is there a repo of user manuals?
I think that is a good start for now
Thanks in advance
Thanks in advance
