I Have a 1999 Argo Vanguard. I replaced the tires with new Runamuck tires and I'm a bit disappointed in the water/Mud performance. tho the ride is nice and it steers on a dime. Have read on the Internet that people do change them for larger tires is this vanguard basically the same as a Bigfoot Argo? They run 25 inch tires and the tub specs seem like argo basically put 25" wheels and hydraulic brakes on her and call it a Bigfoot. ant imput greatly appreciated
argo vanguard Tire replacement ????
gotcha there's not a lot of room and I was wondering about tire expansion when the Argo is going full open. I'll stick to 22's thank you for your input. I've never been stuck yet famous last words but this property is so remote. Trying to be proactive. I read on another blog that people who switch to heavy tread tires and up getting stuck because the tire digs into the dirt and mud instead of on top of it which is what it was designed for. Thank you again
Thank you for your reply, sorry for my late response. still new to this blog. its not the kind of thing you can say I'll just buy them and try them. They don't give these tires away. I purchased the Runamuck tires online actually eBay. But still ended up paying more than I should've. They give a decent ride but they're not holding up to well. I have land in Maine and it's very rocky terrain. Argo tire prices are insane to say the least.
When you upgraded your tire size to 25s did you notice a big difference? I'm contemplating buying just to and see if they fit side-by-side if not maybe I can send them back. What changed for you? Turning ? Speed? swimming? Must've been much better ground clearance that's for sure. That seems to be my biggest issue right now
Measure your axle spacing, if it has 24" center to center a 24" tire will be close and may rub, 25's are out.
What is not holding up in the tire?sigpic
the tread on the tires are wearing down really fast. I have approximately 25 hours on the machine and I don't think I'll get another 25 out of these tires before they're bald. The property has a lot of sharp rock and ledge . I found these tires online. Take a look and see what you think https://www.tires-easy.com/25-12-9/b...ecode/94001637
There used to be an Argo dealer in Grand Junction Colorado. That's where I found my conquest. The tires on it were BKT AT-108 22x11x8 so I asked why. (scientist, I always ask why...)
He told me that the runamucks don't hold up in the rocky terrain of the Grand Mesa and they found that these do. They do require a great deal of power to turn which has to mean that they stress the machine quite a bit more than the runamucks. I understand that they do not swim well but I have never had the opportunity to try swimming. Those tires you've posted look to me that they would be even harder to turn and I'm not sure I would go there.
I do like these tires in the hard rocky ground of the Colorado Rocky Mountains. And they do get me through snow much deeper than I would imagine. I did buy some runamucks to use with my tracks as the BKTs have way too much traction inside the tracks and spin on the wheels causing flats and poor language.
I don't think they make the BKT's like I have any more but that stuff changes so often that I certainly could be wrong there but there are many tires just like them. If I could I would try and find one with less knobbys on the sides. The ride is, well, a bit bouncy but not unbearable (for me anyway) but I do have to keep the pressures up around 5psi because they've all spun on the wheel enough that I think the beads are no longer as tight as new.
