Originally posted by Kris W
View Post
getting the carb off that thing is the hardest part of a rebuild on it. take a picture of the linkage before removal to make it easier on the other end. those carbs have some fairly large ports. needle and seat stuck or clogged, or main jet clogged are likely the issue. also with it removed, make sure the float floats... although if it didn't you would have the opposite problem as it would never shut.
not sure what fuel was recommended for that engine. I tend to be both cheap and lazy about these things. I run whatever fuel makes the engine happy. If you find something that makes good power, idles and doesn't knock or ping, stick with it.
