Anyone know how to remove the stupid little tensioner arms that hold the nylon chain slider blocks ? I busted one putting a slide block on.. It's the arm on the opposite side of the chain from the spring. Not the arm the spring is attached To... Right now it's just sitting there and it looks like it doesn't matter much.. but my fear is if I steer & the chain pulls tight, if that arm spins around and binds into the chain I'm screwed.
WTF ? Everytime i touch something i break (or find a broken) part !
kinda confused here... but the whole chain tensioning thing works like this. there is a big pin that has the two lower and upper arms attached to it,there is then a spring on the pin that gives it movement if it needs to move.then it slides through the frame through a hole and into a shallow hole for the end to go in and then a pin does through the pin and the frame.
