Hi, I have a 2004 avenger. The argo runs with the choke on. I have to put choke and it will go for a short distance then I have to play with choke. Sometimes it want go at all. I wait about a minute and it will start. Go for a short distance then the same thing happens.
At first I tought it was water in fuel so I emptied the gas tank ( took it out of the argo). It went for a short distance and same thing. I checked the fire on plugs and seems to be ok ( good blue fire). I tought it could be a coil and when warms up no good fire but it would run on one cylinder.
I took the carb off and cleaned it, no change. I did not change the fuel filter since I didn't have the right size filter I seems to have durt in it. Could it be the problem? Could it be a carb ajustement? My argo is still in the bush and I have to go fix it there. I'm not a mechanic so any idea what I have to do.
Thank you
Jacquelin
Thank you
Jacquelin
