wire insulation?
  • wire insulation?
    what can i use to keep electricla wires from melting from due to the exhaust? wrap tin foil around them??
    Your best solution is to route them away from the exhaust. For wires that have to be really close, you can purchase some Heat Shield Sleeves from your local autoparts store. Other areas, wire loom should be sufficient.
      the wires come from the exhaust ducts on the side of the argo becuase i have a fan there so there reall it no way around it
        I had this same problem on a Jeep. They make some high heat gasket material that you can get at the auto parts store. I wrapped the wires with a few wraps and secured it with small hose clamps and no more melted wires.
          High temp rated wire might be worth while....
