Hello!
I have a strange problem with my 1994 conquest (kawasaki 620 engine). I had a problem suddenly that it was only running with choke and was weak. I found out that the fuelpump was broken (+ cable was loose inside the pump and impossible to fix). I replaced it with an aftermarket pump (since my argodealer recommended that since the argo pump is extremly expensive!).
The aftermarket pump gives a slightly higher pressure (the pump max at 0.3 bar) then the argo pump but this should not matter imo but the Argo still runs bad and only with choke. I get fuel to the carburator and the volyme looks enough. The problem started with the fuelpump so I dont think there is a problem with air leaking in to the carburator.
Any ideas?
Any ideas?
