do anyone know what is the best tranny to use in the new hunt master 8x8 to run the 18 inch rubber tracks.i have a 2013 750 hdi and I run tracks on that one with no trouble
any info would be great .
The Huntmaster is basically an HDI in camo with some geegaws and the newer machines all come with the 1-3/8 axles in them. The capabilities are basically identical, if you have the low range trans I stick with that, if you have the standard range trans I'd consider the lower range.
