ok got my new seals,first punched them in the the double grease port flange and was good,tried it on the older single port flange and its a loose fit(i can see through it when i pull it to one side
.also do the single grease port flange only use one seal? also if the looseness normal,its loose on every part of the axle not just one area of the axle.
