I made an interesting discovery in the parts manual today for the 2016 Huntmaster. In the back where all the optional parts are listed such as bead lock wheels, front rack, the different seat assembly I found "Litespeed option". In that diagram is a set of 12 tooth "idler" shaft/sprockets shown along with 4 24T sprockets for the shafts driven directly by those idler shafts. The normal sprockets are 11 tooth idlers and 25T driven. Also along with it is a different brake master cylinder assembly plus the steering column assy. and steering arm. So you can see what argo has done here is simply change the sprockets to gain extra speed off the top of their highest speed previous admiral transmission. It looks like they must have also made the brakes less sensitive to avoid abrupt turns at speed. Interesting....
