started her up warmed up for 10 min and went for a ride in back of my house and at 3/4 throttle to full there was no increase in power even when you twist it all the way like it was stuck at half rpm, and the Argo felt very sluggish.tires were all good with psi and had no load abord only me.i noticed once i stoped for a bit and went again she was back to normal but why was my kohler doing this?
no power
Check your filter and the fitting in the tank. If I remember correctly you just had this machine all apart. It's possible you could have dislodged some crud in the fuel tank that has now stopped up your filter or is obstructing the tank fitting....in other words, a fuel flow problem. You could be getting enough fuel to idle and run at lower rpm's just fine, but open the throttle on up and it could be starving for fuel.
