8X8 Argo tracks
  • #16
    Hello Lithail, you can tie the sides together with the bars for your bottom seat bracket, just use heavy wall tubing rather than the stock thin wall tubing. I did this to cure body sag on an older Magnum I used to have.
    • #17
      Originally posted by Lithail View Post
      I am not going to tie them in together as of yet . I was trying to keep the cargo space but if I have to tie them together I will do it near the bottom. Hopefully I can drive it tonight. If your in Ontario. Yea we need snow bad.
      If you are in Ontario. Do you know how I can get an ownership?
      That you would have to get in touch with the factory in New Hamburg about they can guide you thru getting a ownership if you have the original serial plate intact and readable.NCT
      • #18
        I went through this, any Argo dealer can help you (you need to bring the Argo with you). If you do not have the original serial plate they will need the serial number from the transmission to look up the build date and model. Then they will issue you a certificate of origin that you take to the DMV to get an ownership with. many older Argos sold in Ontario were never registered at all, they just went from the dealer to the farm.
