anyone ever installed a oil pan heater on an argo.id like to do this....nice addon for winter! better question did anyone ever put one on a magnum engine.is it dangerous or unsafe,does it work?
oil pan heater
Here is a style that would fit in the tight area of the engine compartment..
Proheat Products : Fluid reservoir pad heaters
Keep in mind that you are only dealing with a couple of liters of oil max! This one is 75 watts and good up for about 2 quarts...
Haven't used one on an Argo but I simply take a covered work light with a 60W bulb and lay it under my Can Am Commander. Used it down to -20F. I would imagine you could do something similar by sliding it between the engine and hull.Last edited by crossbowme; 02-18-2017, 12:43 PM.
