I wasnt getting fuel so i took the fuel pump off to check it out, when installing it back I noticed the top two screws wernt 'holding on' to anything almost as if they were stripped but looking at the threads they dont appear to be. I put a little feeler down in the screw hole and noticed that the bottom is like spring loaded..when i press down i noticed the spring loaded action is connected to the action of the fuel pump valve that moves up and down to craete the suction. The bottom two screws hold the pump and actually fully tighten but neither of the top screws are truly tightening as if theres no thread holding them and they push back due to the spring loaded action thats in the bottom of the hole. Im confused does anyone have input on this? I appreciate any thoughts and insight.
Fuel pump
what Argo do you have...sounds like one with the diaphragm pump so it relys on the engine to create suction. my fuel pump quit on my skidoo,took it apart and it was iced up?? and fuel could not get through it. without your fuel pump securely bolted together its probably not going to operate right?? i dont know i need more info.send a picture of it!
Ya it is the one your thinking of with manual pump. Ill try to uplaod pic. I have the avenger 8x8 w kohler. I think i figured out that top bolt holes have to be perfectly lined up with the linkage to the diaphram there must be threads on those but it feels impossible to line up. Doesnt help that i cant see directly in to try to line it up because its facing the (firewall). Just wonder if theres some trick to lining those up? Tried for hours maybe im doing something wrong. Ill try to post a pic
Store your photos and videos online with secure storage from Photobucket. Available on iOS, Android and desktop. Securely backup your memories and sign up today!
So the one bolt you can see is actually on the top. Those two top bolts arnt catching onto anything but they are not stripped. I found that by moving the linkage side to side (the one that connects to the Diaphram to move it up and down inside the valve cover) it appears that if i line up the holes of the fuel pump just right then it lines up threads on the backside(inside the valve cover) but the seems to 'pop' out of place and i cant get them both at the same times.
Turn the engine over by hand until the pump arm has no pressure on it.sigpic
Depending upon your engine, the vacuum that is required to run the pump is transfered either directly to the pump by attaching the pump with a gasket directly to the engine, or others use a hose attachment to the engine. From the photo, your pump only appears to have two "hose" connections, the fuel in and fuel out (arrows). Thus it appears it should be directly connected to the engine, with a gasket. Thus to get full vacuum, you would need the four screws/bolts to be attached to seal the gasket to get vacuum. Is it possible that the bolts/screws were loose and you lost some, or the wrong size were inserted?
After re-reading your original post, it sounds like your diaphragm pump is a mechanically actuated one, I.E., some lever arm actuates the pump diaphragm. If that is the case, it is quite possible that the diaphragm lever was not aligned properly before the screws attaching the pump were connected. It is also still possible that one or more screws/bolts are the wrong size.
Well I was able to get it..there is indeed a screw plate on the back side inside the valve cover, it just kinda falls back when it was unscrewed. But i had a thought and noticed the oil cap is right next to the top left screw, so I was able to get my (tiny) finger through the oil cap hole and hold the screw plate flush while screwing down the fuel pump and it worked - could feel the screw come all the way through the screw plate. Appreciate all the comments and help, thank you.
