I need to replace the fuel filter on a 2009 Argo Avenger 750 EFI 8x8. That's the filter that's tucked up on the left as you look at the machine from the rear. I only took a quick glance at it, but I'm pretty sure it's a clear plastic filter with a paper element inside. Anyhow, when I checked online the number was 24 050 03. When I checked farther, that looks like a metal body filter that you can't see inside. To complicate matters when I checked with the distributor here in the province, they don't have the filters ... that's the 24 050 03 ... they are on order ... and they don't know when they will be in! Ok, so
1. Is that the right filter ... the metal body one?
2. Is there a substitute that I could use ... say from NAPA or somewhere like that. I really need it now. I'm having some fuel related problems and I'm prettier sure it's a dirty filter.
If you can help, I'd sure appreciate it! Thanks.
