well the fuse dont blow anymore after i tightened the relay wires! but heard a tick noise when i turned the engine over. found out it was the coil was hitting the flywheel every so slightly.... will readjust tomorrow! can i use a credit card to set the coil? anyone recommend anything to set coils?
battery dead....fuse keeps blowing
Carbon deposits can be caused by worn valves or valve guides, improper firing cylinders, work out engine, bad gas and so on. As stated multiple times by multiple users, consult your manual for your specific engine.sigpic
