my dash shows 12.5 and right up to 16V opened up. put a meter on the battery and it only goes up to 14. something. is this a common problem ?
dash voltage
As msafi65 wrote, the gauges can be off in calibration. If your meter reads (13.5)14(14.5) at full throttle you are good.sigpic
my dash shows 12.5 and right up to 16V opened up. put a meter on the battery and it only goes up to 14. something. is this a common problem ?Unless you are having an electrical problem other than the gauge reading, run it. 14 volts at the battery at high RPM is no problem.As msafi65 wrote, the gauges can be off in calibration. If your meter reads (13.5)14(14.5) at full throttle you are good.
