I have a few questions regarding my 2016 hdi I am hoping some of you can help with.
1. Is the hood fan a much-needed accessory for South Louisiana heat? I am having no issue with overheating, but I haven't run it a full summer yet.
2. There is a fan shroud seal kit for the radiator inlet that is available. Should I buy and install for the same reasons as #1? Does it help?
3. With the accessories I already have (front and rear light bar, winch, bilge, sound bar, interior lighting, and occasional hook up of trolling motor or seed spreader) if I add the hood fan kit should I also be considering the 40 amp alternator upgrade? I have heard it's not worth installing...
4. Is there a better tire available than the stock Argo ones for better wear/swim ability? Mine are still good but I will need to start thinking about future purchases.
5. Is it better to run more or less air pressure for everyday non-mud riding? I run 3psi currently for cushion comfort, but my dealer recommended 7psi which I feel is too stiff but is less rolling resistance for the chains.
6. My front chains are stretched to the point of replacement. Some people have said do not use the half links, others swear by them as getting your full money's worth. Is there a final word?
7. I have the other 6 chains adjusted to the 2nd notch on the cams and they are running good for now. I have 3 more notches to go. Do I use all of them before replacing the chains, or will the chain get to a point of wearing the sprockets before then, in which case I change them earlier?
8. I know it differs with use and how well maintenance is done, but is there a common ground for when to start expecting bearing/seal issues? About how many hours?
I have been asking these questions to other people to get ideas as well, but nobody around me has any experience with these machines. We just don't see them around here that much. I appreciate any answers you can provide to help. And before I get beat up, I have read through the manual many times and have only found standard 'safe' answers, or no answers at all. I depend on your experience for real world answers. Thanks!
cdover73
cdover73
