Hi Steve, have a cold one and watch me get stuck in the muck. https://youtu.be/XRkCkqj7NJo
My first Argo configuration advice and questions.
Is the which optional from Argo or one you are purchasing yourself?
Either way if you can get synthetic line I can't be adamant enough about how much better they are than steel which lines.
Much lighter
Much stronger
won't kink up and twist
won't bind on the drum
won't rust
won't stab into your fingers with tons of tiny little metal burs over time
most importantly won't snap and de-limb everyone in the immediate area
Steel which lines work
Just like steel body armor in the medieval ages, just like body armor we have moved to Kevlar / more advanced materials for a reason.
Also what power output on the winch? On an 8x8 you want a decent output more truck level than ATV (if only to pull other stuck people out ;-p )
I approve of Juggernaut on the Hood
There was a lot of discussion on tracks in this thread not sure on what decision you came to. Tracks can make a 6x6 / 8x8 multitudes better under (most) circumstances off road but don't underestimate a machine with only tires. Simply put. You can get stuck with tracks you can get stuck with tires. Tires are simple and have a lot less to go wrong. It seems like in every track tread there is arguments about which track is "worst" not best. People point out their inherent flaws vs one another more than their gains. That's just my 2cents. Either way you'll have fun.
The thing that attracts me to tracks is the fact they would be a lot harder to puncture than the cheesy tires. I drive in clear cuts and rocks and sticks and sapplings have punctured tires but not the tracks. I just mow over the jungle to get to a deer that is down in a ravine. I drive over stumps from time to time when I don't see them. Try doing that in a UTV.
Barrows Argo is researching the winch cable as to strength. The 2013 SE model had a rope like cable. Since the tracks I will be using are Escargo, if it does get stuck, then it will really, really be stuck, so I have to make sure the winch cable is strong enough to get it unstuck. My priorities are unstoppable, usability, comfort, and asthetics.
Steve
I need to add durability to the priorities. The components chosen are the strongest available. I will have the winter kit for the Escargo tracks, but won't need it unless we get 100 feet of snow. I got responses for and against certain hardware. My motto became "I would rather have it and not need it, than need it and not have it."
Steve
Some things are still fluid, but I can describe what I know. As I mentioned, there was conflicting advice, so as I am a software engineer, and I work with mechanical and electronic engineers, and I have a good friend who is a machinest, I made some decisions. First, everyone agreed that I don't need the auto chain oiler, and I agree. Second, everyone agrees that the alternator is a good idea, and I agree as well. A question I had, was what charges the battery without the alternator, and I knew regulator/rectifier did not produce a charge. The answer is a magneto. OK, the battery will be Optima, there will be a brake fan, and under hood fan. The addition of the under hood fan stops a lot of the heat from the heater in the summer. Yes, I decided to go with the heater. The transmission will be the HT. The drive belt will be HD. The winch is still uncertain, but the fog lights will not be Argo, but third party controlled by a remote. The winch will be controlled by remote also, and have the rear winch receiver. The fog lights will be mounted on the top of the brush guard. Of course the windshield will be there, and it will have dual electric windshield wipers. I know they can break, so I will put stronger arms on them. I considered the manual wiper, but didn't want to be wiping with one hand, and driving with the other, especially as I get older. The full cover will have zip down screens, on all 5 positions. Between the two windshield wipers, will be a round mirror, so I can see behind me. The outboard motor bracket is a must, and the electric start motor will have a fuel disconnect from the main Argo fuel tank. There will be a paddle attached somewhere, and the utility pouch will be behind the front bench. The hand rails will be there, and I will buy or build folding stairs so my wife can get in and out easily. The trailer will be an extended height, so I can drive in and out with the cover up. It will be silver, as white would show the dirt, and black would make it way to hot inside in the summer. There will be brackets in the trailer to attach hold down straps. Juggernaut will be painted on the hood, so it won't interfere with the boat and OHRV registrations. The tracks will be full Escargo with track tuners. The winter kit will be here, but seldom used. As more things get finalized I will post them. The color will be red, and although I haven't seen the new models yet, it will likely be the Avenger STR, or similar.
Steve
Good idea. I will hide them as much as possible. I'm not sure how big the water anchor will be, but certainly smaller than the land anchor. Perhaps it can git under a bench. I will know more once it arrives in October. They have that extra fuel rack on the back, which could double as a hold something else rack.
I forgot, but I will have the mud flaps so mud and water won't be sloshed in the cab when the cover is down.
Steve
Hi Steve, you will have all the best options on your new Argo... but you haven't mentioned getting a plow. Living in New Hampshire that might be nice. I'm guessing you have a plow for your vehicle or a nice snowblower. Speaking of snow here is a short ride video out in the New England winter https://youtu.be/HFNbGg28QBM
