I found a few minor things I had to get fixed on the avenger before my big moose hunting trip next week. Got them all done but one thing I noticed is what sounds like chain rubbing noise when decelerate from high speed. It is almost like the chains slack up and sag enough to rub somewhere.
I orginally thought it was from the main drive chain from the transmission/brake area, as it was loose. I tightened that up but it is still there.
Again, there is no noise when driving, only when I let the gas off and start to decelerate. Then I get what appears to be a rubbing sound.
I have new chain adjusters all around (the new style). The chains all appear fairly tight.
IS this normal and if not, any ideas where I can look first?
Derek
PS. I "think" they are rubbing on the cross brace that has the black plastic sleeve piece that sits on top if it. (right below where your feet would normally be). The chains may be slacking just enough that they are rubbing when they go over that black plastic.
Derek
