just went to go for a ride and i cant turn right. the pads are moving and caliper seems to be working but no to very little turn forward and reverse?
no right turn
Welcome to the world of spiral pins, locking up each side watch each wheel to see if they are all doing what they should be In Unison.
If so and no sprockets have missing teeth and no chains are bound in a goofy position from rust ask again.sigpic
Ok then, removal of the brake disks may reveal broken/sheared drive keys (key stock).sigpic
Maybe try swapping pads side to side, if possible, and see if the problem changes sides.See my photos here.
https://www.flickr.com/photos/giarc_dranrab/albums
Videos:
https://www.youtube.com/channel/UC8m..._as=subscriber
What machine are you playing with, Your Magnum or the I/C ?Originally posted by curtisbyrne View Postthe only thing i done was loosend off the three power-pack frame bolts and adjusted the idler chains. i never touched the calipers. i notice when i moving slow and i just ease the right brake it makes a noise not like chain jumping over sprocket but like vibration that you can feel on your hand?
Did this machine work good before you adjusted it?
Did you change the gear oil and was it full of a silver hue?
Tell the whole story.sigpic
