I have an Argo 8x8 Conquest 1997 and I have some questions regarding the machine.
1. When too much water enters my Argo, usually when I clean it or if there has been some heavy raining, the transmission has a very hard time to gear up. Is this normal behavior? I usually drive it into the forest and empty it using the bilge pump.
2. What's the recommended tire pressure for SuperTracks? The manual is making it a bit hard for me to understand. I've read that it should be 3.5 psi on all tires, different pressure in the middle ones in another place, highest pressure on all tires..
3. I've also read somewhere that it is not recommended to drive around on the low gear, but according to the previous owner you need to drive with low gear if you are using the tracks. I confirmed this simply by trying to drive in the high gear and, well, it did not like that.
Thanks in advance for answers!
