Ok, I'm embarrassed about this one but I can't find the transmission drain plug on my 70's model Argo. The oil in mine is looking kind of milky and I would like to change it but I can't find the plug. Anyone know where it is on this tranny? Also, should I just put 90wt gear lube in it?
Transmission Lube
my 80 something argo, the plug is on the front of the trany, bottom right. i couldn't find mine either, but located it once i had to pull the trany out. recomended fluid 75/90 gear oil (per argo) might be different in different climates... i'd check with a dealer in your areaA well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
most marine stores sell vacuum extractors for around 20 bucks. a hose goes in the fill hole to the bottom, and you run a small pump with a cordless drill. works best if the fluid is hot (especally on gear oil). a heat gun or the wifes hair dryer should get it warmed up quite nicely.A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
