2008 Argo Frontier 650 6x6
  • 2008 Argo Frontier 650 6x6
    New here but I have been reading the forum. Hope everyone is doing well.
    I'm looking at a 2008 Argo Frontier 650 6x6. It has the 23 hp. Briggs. I ran it around tonight and seemed to run decent. When I turned the throttle it did have a slight hesitation and picked up. I was told they put a new carb on it and they paid $300 to $400 for the new carb and they had to get it at Argo to get the right carb because they couldn't find it anywhere else. It had been sitting a while before they got it running again. Also when turning to the right slightly it turned good but when turning to the left it took a little more turning the handle bars to the left side than the right turn took. Handle bar sitting turned to the left slightly when driving it. I'm thinking a slight cable adjustment for the left brake. Chains and sprockets looked good. Original Argo tires but a couple of them had cuts or cracks in them about 3 inches long. Rims had a few dings. Over all looks to be in good shape. Also I looked to see if there was a 3.3 stamped by the dip stick on the tranny and didn't see one. So standard high/low tranny.
    Questions:
    What is everyone's thoughts on these hours?
    How thick is the side wall of the Argo tires? Maybe put tubes in them?
    What else should I be looking at before I consider buying it?
    What is a good price?
    Thanks for the help.
    Joe
    Hello and welcome! I am the owner of a 2016 Argo Frontier Scout and still learning all I can...
    Regarding price, for comparison, there’s a 2007 frontier 6x6 in Vermont (on Craigslist) with 600 hours and the dealer is asking $7000 for it. Someone else will chime in and comment on this I’m sure...
    Sorry I can’t help with any of the issues you’re concerned with!
      tires are 4 ply,when you say chains looked good do you mean just shiny or good and tight with not to much slack? jack it up and check bearings!
        look through this!
          Hello Joe, welcome to the site. I have a 2009 Frontier 480 with a 14hp that has almost 400 hours on it. Great machine! My sticks are a little to the left as well and it turns easier to the right also. You can adjust the brake cables and i also had to replace the aluminum collar down the handlebar shaft due to force on the handlebar. I would check the front sprockets as mine are needing replacing as well as the jackshafts. My tires have issues like plugs and slow leakage but nothing a little air now and then doesn't fix. Price wise i would price mine around 5000. I have seen brand new 2015 and 2016 frontiers that dealers were trying to dump for 8999 a few months ago. Hope this is helpful
            Not sure where you are located Joe Clean machine great price
              That is a great price and very clean Rick. I'm in Ohio.
                Thanks Mowbizz
                  Thanks for the replies everyone. Curtis the chain tension is tight. I checked in several locations. The sprockets are in good shape as well. The second owner used it to run around on a gulf course he owns. I don't believe it has ever been run hard. Most likely cruising the golf coarse.
