I broke through the ice on the river for the first time this past winter. What I didn’t count on was that the ice broke and dropped one side into the water. It was all I could do to keep from flipping over as the Argo slid sideways of the ice into the water. Fortunately I hit the bilge pump very quickly and kept my composure until we settled down in the water. I really believe that we would have flipped had I had a passenger at the time. I have an Argo 8 x 8 Frontier scout with tracks. I also had a hell of a time getting that Argo out of the water because there was a space of about 4 inches between the layer of ice and the surface of the water in that river.
Argo 6x6 on frozen lakes
Originally posted by Drenthe View PostI broke through the ice on the river for the first time this past winter. What I didn’t count on was that the ice broke and dropped one side into the water. It was all I could do to keep from flipping over as the Argo slid sideways of the ice into the water. Fortunately I hit the bilge pump very quickly and kept my composure until we settled down in the water. I really believe that we would have flipped had I had a passenger at the time. I have an Argo 8 x 8 Frontier scout with tracks. I also had a hell of a time getting that Argo out of the water because there was a space of about 4 inches between the layer of ice and the surface of the water in that river.
I used my winch and a 27’ tow strap. Was fortunate enough to be able to get the strap high up (12’)in a tree. This was necessary to lift my front end up and then use the winch to get back on the ice. Very very fortunate that I had a tree that I could get to.
You can also use a log for an angled up pull if you are too far from a tree. chainsaw a small hole in the ice about 30' away from your argo and wrap your winch cable around a short 2x4 or strudy branch to use as a toggle and push it through the hole to anchor it under the ice. Then stand a 5' tall log up under the winch line closer to the hole your argo is floating in. You'll need a 2nd set of hand to hold the 5' log stable while you tension the line.
