I'm currently running 18 inch rubber Argo tracks on rawhide tires 25x11.5x9 on an 04 Argo avenger. Everything has been installed as per specs. However if I use tire pressure 5,7,7, and 6 psi as per specs I can't come close to the required min sag of 2 inch. I know if I run tight tracks I will stress my running gear. The only way I can gain the 2 in sag is with 3,4, 4, and 3 psi or less. i suspect there is more rubber to rubber contact with lower tire pressure. Any suggestions ?
Track sag
I have that exact same set up. '04 Avenger with 18" tracks. I also run the Adair Track Tuners. I generally try to "feel' my way to the correct tire pressure. If they are slipping I'll add air to the corner tires. I used to have a spacer in the tracks for many years and then I think the tracks must have stretched a bit so I removed them. I probably have a 1 1/2" sag. I still have several of the original "04 tires and they occasionally leak but I have been replacing them over the past year or so. For me its all about adjusting the tire pressure
Yes, I have one 2 inch spacer on tracks. Perhaps I should add I have two tires with tubes and two tires I've had vulcanized, however can't see that making any difference. (Dry snags and soft side walls don't get along well.) I remove the tracks in summer. My summer treks are over varied terrain, old hard surface abandoned logging roads, muck, water....and tires alone will get me there. Winter conditions, tracks a must...no question in my experience.
The rubber tracks stretch a lot real quick! Pay attention every ride on your tire pressures and track sag the first 50kms or miles. At first I had the metal spacers but within 30 kms they were off and running 3.5 psi in the corners and less in the middle tires (only because I ran track tuners). I would run as little as possible for a better ride but enough not to slip the tracks in snow or water. I found in the winter I would run about 5psi since I was always in snow and everything was cold and slippery or it would spin in the tracks trying to climb hills.
Originally posted by Sparx View PostThe rubber tracks stretch a lot real quick! Pay attention every ride on your tire pressures and track sag the first 50kms or miles. At first I had the metal spacers but within 30 kms they were off and running 3.5 psi in the corners and less in the middle tires (only because I ran track tuners). I would run as little as possible for a better ride but enough not to slip the tracks in snow or water. I found in the winter I would run about 5psi since I was always in snow and everything was cold and slippery or it would spin in the tracks trying to climb hills.
Live and learn!
Just got back from the bush. Mild, wet and soggy snow conditions. 2 inch sag with psi 3, 4.5, 4, and 3 not cutting it! Serious tire slippage. (As suggested). Normally been winter driving under frosty dry conditions. I'm off the opinion that 1 inch sag is ok on snow and ice....but I could be wrong.
Originally posted by Murray40 View PostJust got back from the bush. Mild, wet and soggy snow conditions. 2 inch sag with psi 3, 4.5, 4, and 3 not cutting it! Serious tire slippage. (As suggested). Normally been winter driving under frosty dry conditions. I'm off the opinion that 1 inch sag is ok on snow and ice....but I could be wrong.
