I have an Argo Frontier with a 9.8 hp outboard motor on the back. We operate it in very sandy conditions and river current. We are experiencing problems with sand being drawn into the water intake and clogging it . Have any of you experience any problems similar to this? We are looking for a solution.
Argo Frontier with outboard motor
Long shaft and sandy shallow rivers with thousands of sand bars. Thinking the only option is an air cooled motor.Originally posted by BW3 View PostLong shaft or short shaft? Stock motor mount? .....maybe the water condition you run in ? Sorry not much help just thinking out loud as to causes...watching this for others input ...worn pump on your outboard ? ....
Make of outboard?
I don't think there's an easy, cheap fix for this. Inboard, outboard or I/O set up will not tolerate sand ingestion very well. What the southern folks call Mud Motors may be the only reasonable solution. I think their claim to fame is use of air cooled engine as opposed to handling raw water for cooling.sigpic
Argo with outboard motor
Just curious Delduck, Would you think that the 10 HP Go Devil would be less "cumbersome" on A rear engine machine like an Argo Avenger?Originally posted by Delduck View PostIt is heavy I used a 10 hp go devil long tail motor on my max 4 it was very light, but took it off because it’s just cumbersome
On my MaxIV the first issue to overcome trying to use an outboard motor was the high rear engine cover. On my Avenger the problem is needing a really long shaft to reach the water!!! (especially if the driver wants to stay in the front seat and steer using the Argo engine and tires). I would love to try a Mud Buddy or Go devil type rig if I thought that turning it around end for end would let me carry on through the bush after crossing the lake.
