master cylinder
  • master cylinder
    i had both brakes working last week and now the left brake lever just bottoms out and the pads dont squeeze the rotor. i took apart the fluid reservoir again and blowed all the holes out and brake line like i did last time but this time with no success. i removes the line from the reservoir and nothing comes out of the hole and seems its not getting to the caliper? what needs fixing here. the piston in the master cylinder is a nice fit and the the seals on the piston seem good.
    anyone??
      Try backing the adjuster off until you get it bled, often times the adjuster is to far in to allow fluid to flow. Just open caliper bleader and let the fluid flow at first, it may take some time.
        i dont think these are adjustable like mine where its collar and grub screw. its just a little knob like object that pushes on the piston.may have to look again i was thinking it couldn't be adjusted?
          got it working loosed off the nut a bit at the end of the lever and it worked.thanks alot!
