Hi All
My avenger 700 is playing up. Basically it is not starting well, with loads of back firing and rough running when it eventually starts, though eventually it will start and when running is ok, though down on power. The problem is intermittent, though happening most of the time. It appeared to happen after a bit of a bash whilst in the hills.
We have checked the exhaust, as we were told it can break down, but it is fine. We have checked the push rods, and they are straight. Carb and solenoid all appear fine.
Plugs are oily, but it has been starting and stopping on the choke so i think that is ok. So it sounds like it is an ignition module breaking down. I have a spark tester coming tomorrow and this will help confirm it is spark related. Does this sound like i am going in the right direction?
Firstly has anyone the part number for the modules, as ebay has loads, and they are way cheaper online than the UK dealers. Is it possible to change the ignition modules with the engine in? It looks like if i remove the radiator i should have reasonable access to remove, set and replace them. Is there anything else i need to check or consider? Fuel is new, carb has been cleaned out and was perfect anyway, filter is new, airfilter is clean, and after the bash it ran a little more rough all the way home and then the difficult starting started. It has been a superb starter, and even after the bash when it eventually started it ran for hours and pulled really well, it just had a perception of running slightly rougher.
Any help very much appreciated.
Dave
Dave
