Hi
My 1996 conquest with Kawasaki engine are suddenly showing high voltate at high RPM. And the voltage meter needle is peaking above 14 volts and vibrating, the water temperature needle is also vibrating. Hence my thinking is that somehow the alternator is giving to high voltage and unstable voltage since voltage meter needle and temperature needle is vibrating like crazy.
I suspect the alternator regulator or rectifier bridge (Diodes).
Maybe just as well to by new alternator ?
Or could it be the regulator, there is one box thing right side of the "dashboard" below the voltage meter.
What I am also puzzled with are that the alternator says regulator inside, if there is a regulator there why is there an external regulator.
