The Argo web site says the Aurora 950 with a Standard transmission has a top speed of 20 mph and 17 mph with the HT transmission, must have been a misunderstanding somewhere by ATV magazine.
New argo aurora
Originally posted by mightymaxIV View PostThe second video does state the the 40mph top speed is available with the 40 horse engine. 1 issue I already have with the machine is the one piece floor pan, it takes me about 15 seconds to take out the rear floor pan on my 6x6 to see if I have taken on any water. What are you going to do with this machine? Checking for water is a big deal to me and I would like it to be as easy as possible.
I think what Dan was getting at was the one piece floor pan is complicated to remove for checking and lubricating the chains. Pretty much everybody I know will pull the drain plugs on a slope to drain water out while out on a ride. For example, the factory Max 2 one piece floor pan is a real pain to pull out, and most of us have segmented the floor board into two pieces to expedite the process.
Argo historically has had front and rear floor pans that are super easy to remove.
I would disagree with that. Rear floor pan, yes. Front one, not so much. At least, on my Avenger 750EFI it isn't exactly easy. The firewall has to be removed first. And that's a pain because of how it fits. Besides, who needs to check for water in the Aurora, if it has a built in bilge pump as a standard accessory?
Originally posted by Sparx View PostWhat's wrong with just pulling the rear plugs to check for water? That's all I do, park it on a slight incline to help make sure it's all drained out for 15 mins and good to go again.
Originally posted by Deedeelin1 View PostMr.Edwards, Remembering the good times, When we were riding durning Hurricane Matthew, we were stopping about every 5 minutes draining the water out. GOOD TIMES
Originally posted by mightymaxIV View PostWow, sounds like you guys have never had an issue, on every ride I pull my floor pans out two or three times, I am not only checking for water but my spockets, my chains, my adjusters, my bearings etc., I blew a bearing on the output shaft of my HDI and didn't even know until I pulled the floor pans. I also check for damage to the floor pan, why? On one ride I knocked the revits loose on my skid pan on my HDI, my son took the machine into a lake to wash it off and took on water so fast he nearly sunk the machine
Originally posted by mightymaxIV View PostYes, in east Texas I lost an alternator, I had to cut three different rides short because the charging system on my frontier 8x8 had been improperly installed and caused the wires to ground out and discharge the batteries, blown bearings, broken chains, clutch key ways coming loose, yes I have learned to check my machines and to try to have at least one aatv with.me when I ride.
Steve
