Is there any issue with putting a second master link on chain? I'm replacing a couple of single 60 chains and will have 2 pieces with 34 links in each.. If I needed another longer one, it would save buying another box and having a 3rd section of 34 links...
2 Master Links on 1 Chain
My only input on the subject is this. Whenever i have had a broken chain it has always been the master link that goes. So two master links in one chain doubles the chance of that chain breaking IMO.Originally posted by glen1971 View PostIs there any issue with putting a second master link on chain? I'm replacing a couple of single 60 chains and will have 2 pieces with 34 links in each.. If I needed another longer one, it would save buying another box and having a 3rd section of 34 links...See my photos here.
https://www.flickr.com/photos/giarc_dranrab/albums
Videos:
https://www.youtube.com/channel/UC8m..._as=subscriber
Where they actually broken or did the clip come off allowing the link plate to come off then bending/breaking the link itself, or did the link itself fail?Originally posted by Craig_B View PostMy only input on the subject is this. Whenever i have had a broken chain it has always been the master link that goes. So two master links in one chain doubles the chance of that chain breaking IMO.
We repeatedly see the sliders groove and kick the clip off, it can be caught if found in time.
Most broken links I have seen have been riveted links, often times on oring chain.
I have often run multiple masters.sigpic
Yes I suppose that could be the case. All I know is that where my chains have failed.Originally posted by ARGOJIM View PostWhere they actually broken or did the clip come off allowing the link plate to come off then bending/breaking the link itself, or did the link itself fail?
I have often run multiple masters.See my photos here.
Videos:
Any chain is only as strong as the weakest link. If one master is ok then 2 or 10 or 50 are as well. Make sure your clip is facing the correct direction so the direction of rotation does not knock the clip off. The opening of the clip should be to the back (in direction of rotation or opposite of direction of rotation) just in case it slaps something at just the right time so the clip doesn’t get knocked off. Once the clip is knocked off the master link will bend because it will be a c shape. On dirt bikes it is usually knocked off by a stick but the Argos would likely be frame or worn slider contact.
