I just picked up a 2013 frontier 6x6 with the admiral transmission , unit has 82hrs on it and 300km. My hunting partner weight about 175lbs more than I do, can I expect it to always pull to that side?
Does your Argo pull to the side with a heavey person beside you
I’m the heaviest one that rides in my Argo and it still pulled to the left with 2 of us seated. Softer tires on the left side was the culprit. Try as I might to keep the tires all the same it seems like they have minds of their own....Originally posted by grit View PostI just picked up a 2013 frontier 6x6 with the admiral transmission , unit has 82hrs on it and 300km. My hunting partner weight about 175lbs more than I do, can I expect it to always pull to that side?
My attex tends to pull to the side with more weight. Both on land and in the water (but probably 2 different reasons), kinda makes sense. You're squishing the tires down more on that side, the tires on the other side have a larger radius from the ground to the axle so it'll pull to the heavier side. Just the nature of the beast.
