Hi ,Has anyone tried running argo tires on the rear only for water propulsion and off road tires on the front for better traction and reduced cost of replacing all tires with the expensive Argo paddle type.
Argo tires
It’s my understanding that the stock tires really don’t paddle that well to begin with, thus the slow water speed. Not sure having only one pair for swimming would be adequate at all. That said, go for it!
Plenty of mods have been done on these machines from A to Z!
Try it and see! Good luck!
I struggled with the cost of the Argo tires when I needed 8 new ones. But it was the best decision in the long run going with the Argo tires. If your not doing deep water crossings all the time then go with different cheaper ones. You need all Argo tires all the way around if you want swimming speed. The owners that say the Argo paddle tires don't swim well don't understand the purpose the Argo is built for. That's why they can put a boat motor mount on. The new Argo tires have eliminated my need for my tracks, other than in deep snow.
Originally posted by allwheeldrive View PostI can see the logic in just having rear paddle tires. With one person Argo's sit so low in the front really only those rear tires are doing work I'd think.
Using tires other than the Argo, Goodyear, Vendetta ( exaggerated Runamuk) paddle design causes cavitation although the Rawhide style tread does next best, for example a knobby tire will act much like some tracks and actually propel you rearwards slightly while you are attempting forwards.
Other than money there is a reason the machines come with these tires, helping make them Amphibious vehicles.
However I'd also say give it a shot if you have some, a little feedback either way on an idea is always welcomed and informative.sigpic
Thanks for the feedback ,I do have an outboard 8 hp motor but have replaced the worn out argo tires with after market knobby tires ,great off road but looking to get some propulsion to get out of shallow water into deeper water where the outboard can take over, maybe I will buy 2 at a time and see if it will work if not i will replace all the tires ,do the new argo tires last longer than the old runamuck tires only got about 500 hours out of them.
If you watch craigb's video, it appears his machine goes descent with the Duro tire mounted in the dig position.
If you can find nankang chevrons over there they swim well.sigpic
Originally posted by glen1971 View PostI've never noticed my argo to sit lower with one, two or 4 people in it as there are no springs to compress. My understanding is the rear wheels don't ride on the ground to aid in tighter steering (center of machine is now the 2nd wheel, instead of between 2nd and 3rd).
Front end heavy which makes the rear tires more exposed therefore able to do more work paddling.See my photos here.
https://www.flickr.com/photos/giarc_dranrab/albums
Videos:
https://www.youtube.com/channel/UC8m..._as=subscriber
Originally posted by Craig_B View PostI believe allwheeldrive was referring to how the Argo sits in the water. Not on land.
Originally posted by oz argo View PostThanks for the feedback ,I do have an outboard 8 hp motor but have replaced the worn out argo tires with after market knobby tires ,great off road but looking to get some propulsion to get out of shallow water into deeper water where the outboard can take over, maybe I will buy 2 at a time and see if it will work if not i will replace all the tires ,do the new argo tires last longer than the old runamuck tires only got about 500 hours out of them.
Originally posted by Jbd View Postif your going backward faster than foreward your tires are probly reversed.
Originally posted by Jbd View Postput all tires facing the same direction and you'll have full swim speed forward. reverse speed is almost non existent but you will turn on a dime so reverse swim not needed. open "V" forwards. your tires are fighting each other.
