Have an older magnum 8 x 8 with stock tire size of 20x11x8, I thought the magnum had wider spindle spacing to accommodate larger tires.
I'm trying to track down 8 replacement tires, wont be doing water crossing so not concerned about V tread pattern. I've looked at Carlisle, Duro and several other brands but not much in that stock size.
Is there any issue running 21x11x8 as there are more tire options in this size. Its funny as some 20 tires are actually quite a bit taller than the 21 inch tires I guess because of brand.
Thanks
Thanks
