Hi All
I have an avernger 700, and the hand brake feels like the cable has snapped. I am told that there is some form of block in the system, over the wheels where it is secured and this often breaks, causing the symptoms i am experiencing. My expert tells me it is a body off job to properly repair, but i am wondering if there is an alternative. My argo is for hunting only, and never needs to swim. I am wondering if some form of u bolt clamping the cable either end of the damaged retaining "thing" could do this. My plan is to put a camera under the side to see what is in there and see if this likely to work. i have found a screw through the hull about where i would expect the fixing point to be so know roughly where to look. if it is possible i will just make a small porthole on the inside of the top hull on the cab inside and if the camera shows this will work will pop in a u bolt.
So, will this work, has anyone had a similar problem and if so how did they fix thsi?
cheers
dave
cheers
dave
