avenger tire bounce
  • avenger tire bounce
    My avenger has been sitting a while. When I took it out today, it was bouncing quite a bit. I am assuming because it was sitting for so long, the tires have like a flat spot on them. My question is, does this go away? I put it up on blocks and put alot of air in each tire. I am hoping that takes care of it.
    That should go away after you drive it for a while. I have some bias ply tires on my Jeep and they do the same thing.
      Avenger tire bounce
      I've got the same problem with my Max II.If I do a lot of mileage it heat up the tires and seems to get better.When I don't intend to drive it for a while I lift it off the floor.
        Boy have I got this problem in a bad way. The Amphicat I bought has been sitting for 30 years in the same spot on a concrete pad with flat tires EEEEK
        The one piece wheel/tires are still good looking tread and crack wise and hold air just fine (shocking), but its a rough ride. I have only rode it around my yard because its so bad.
        Any tricks here ? Or just keep riding it around and hope for the best?
        ST400R ATTEX(Smiley)
        500 Super Chief
