After replacing all bearings and seals I decided I may as well replace the chains. Just put on a rear chain and it seems they're pretty loose. Tensioner has new friction pads and are all the way up but chain lays across top frame crossmember and bottom touches the hull.
Manual says they need 2.5" slack and I guess I have about that...but they do seem pretty loose. When I got the Argo old chains had rubbed holes in the tub under the sprockets. Those holes have been welded up but looks like it might happen again if they stay this loose.
Do they tension under load when running? Installation seems pretty simple but could I be doing anything wrong that might cause excess slack?
