2 years ago i bought a new fuel pump for my argo magnum at an argo dealer worked fine for a year then it quit. bought a new one two days ago put it on worked fine for a day now its not pumping again. i ran it from a clean jerry can with no dirt and it has all new fuel lines and filter and new carb. this seems to be n ongoing problem for this engine and me anyone know what it could be ive had it with the engine and not pumping fuel. the fuel pump is the one that runs off the cam by the way
no fuel
I had a similar machine years ago. the pumps seem to lose prime. if you can reprime them they work fine. you could try adding a squeeze bulb primer like you would find on an outboard boat engine, or a low pressure electric pump wired with a toggle switch. in either case it would help with priming and you could use it during the long uphill fuel starvation situation that those machines were prone to.A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
ok i will give that a try the only thing i can think is where the arm rides on the cam it is worn down to the point where it cant get a full up and down motion for the pump to pump fuel. do you think that could be a possibility? it only has 800 hrs i would think it would last longer if this was the case.
could be, but I suspect one of the cam lobes opening valves (really doing work) would wear first... I've seen this on a few of these engines. I think you are just dealing with a weak diaphragm pumpA well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
I was having a priming issue on my 2000 Response. The pickup tube in the tank was deteriorating and allowing air into the fuel system. We replaced the pick up components and no further issues. Might want to check into that part of the system.
With the fuel pump removed. If you rotate the engine slowly you should be able to see a cam lobe which actuates the pump. Is it there or not? Did you try priming the pump in the manner(s) I suggested?A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
got it working its pumping fuel. took it for a ride and 10 min in it just died and smoke came out of the carb and exhaust. it started up after sitting for an hour but the fuse to the far left on the fuse block blew im not sure if that was a main fuse or not. the 30 amp from the stator was not blown only the one on the block.
Here is my guess
Cracked pick up tube, will allow pump to suck air. If you remove the toolbox you can visibly check it, attempting to pull the fuel line off will most likely break the tube of not currently broken.
Another possibility could be fuel line breaking down internally.
Next tank vent not working properly perhaps causing 1 of 2 problems, possible 10 minute shut down, possible suction emptying fuel line at shut down.sigpic
ya found the problem the tube in the tank wasnt connected to the little fitting on top of the tank. but i fixed that before i went on my ride so getting fuel is now not an issue. it starts fine but it runs like crap and smokes black regardless of the carb being set to factory and making adjustments.
No Fuel
Hi Curtis- Glad that you got your "No Fuel" problem sorted out,congratulations. I'm sure that you can get your black smoke, carb problem fixed too. I think we should give a cheer to Argo Jim for hitting the "no fuel" solution right on the nose!!:Originally posted by curtisbyrne View Postya found the problem the tube in the tank wasnt connected to the little fitting on top of the tank. but i fixed that before i went on my ride so getting fuel is now not an issue. it starts fine but it runs like crap and smokes black regardless of the carb being set to factory and making adjustments.
cleaned the carb again noticed it was leaking around the bowl and tried it again and its still leaking... no matter the adjustments on the carb as soon as u give it some gas it sputters and runs rough it idles and starts fine tho... anyone know where i can buy a KOHLER carb for this my old one is toast.
