I just bought a new 2018 frontier 8x8 and I'm thinking I will likely get tracks for it next fall for ice fishing. I was thinking 18" rubber. Anyway, is it correct that you just have to turn the tires around and mount them reversed to be able to fit the 18" tracks on them? I have the 24" x 10" tires.
Super tracks for a 8x8 frontier
The 18” rubber track kit for your machine requires NO SPACERS so you are good to go.Originally posted by Jeffrey K View PostI just bought a new 2018 frontier 8x8 and I'm thinking I will likely get tracks for it next fall for ice fishing. I was thinking 18" rubber. Anyway, is it correct that you just have to turn the tires around and mount them reversed to be able to fit the 18" tracks on them? I have the 24" x 10" tires.
My 2016 tracks requires the spacers and has them installed.
Yup...pony up the $$ the first time and be happy! I went round and round forever with this track and that track and am very happy with the 18” rubber for New Hampshire winter conditions. Best combo for ice fishing bar none!Originally posted by Jeffrey K View PostThank-you.
Several years ago I had a set of standard 12" tracks in plastic and I was never too impressed with them.
I was hoping the rubber would fit on this new machine.
I have had the rubber tracks for the past 4-5 years and they are great. I did add the ice cleat kit but think that I will be adding ice studs this year as there are some hills I cannot get up with very hard packed ice.
I mean hills that you have a hard time walking up.
Woooooaaaahhhh! It depends on when your machine was made during 2018 if your machine came with the offset/reversable rims and the big 1.375" diameter axles. I was glad to find out that my 2018 Frontier 8x8 LE was made later in the year and had the upgrades. Here are the parts manuals from the Argo Adventure Web site that out line the serial number cut offs.
2018 From Serial No 40943 Frontier 8x8 S Parts Manual (Feb 2018) (1.25" Axles / Bearings - Std Rims)
2018 From Serial No 41791 Frontier 8x8 S Parts Manual (Feb 2018) (1.375" Axles / Bearings - Offset Rims)
So if your machine was made earlier in the year and does not have the off set/reversable rims than you need to run spacers on the stadanrd rims with 18" tracks.
The easiest way to tell if you have the off set/reversable rims is if they have a air fill stem on both sides. You can reach around the front and back rim on the machine and feel for the stem on tht side.
Thanks for that...leave it to ODG to add confusion to the mix. When I bought the tracks from my dealer, the instructions that came with them were WRONG. I hesitated cutting the tracks until I was sure about the length to cut them at (too short and $4500 down the toilet) finally, one person at the dealership came up with the CORRECT set of instructions for the track build/install. That, and when I got all the boxes home, the SPACERS AND EXTENSION STUDS were not there! Another call and they overnighted them to me...Originally posted by thorn View PostWoooooaaaahhhh! It depends on when your machine was made during 2018 if your machine came with the offset/reversable rims and the big 1.375" diameter axles. I was glad to find out that my 2018 Frontier 8x8 LE was made later in the year and had the upgrades. Here are the parts manuals from the Argo Adventure Web site that out line the serial number cut offs.
